Date/Time: Tue, 04 Feb 2025 14:50:43 +0000
Where do I find my previous software version?
View Count: 1019
[2020-01-30 02:13:18] |
CLscalper - Posts: 28 |
I received an email from TopStep Trader that as of tomorrow I need to run version 2037 or earlier in able to continue using Sierra with their Rithmic data source. I updated to the latest version this morning (2040) and now need to go back to my previous version which still supports Rithmic, but I can't seem to find it anywhere. I did try and run version 2037 but it gives me a "Rithmic" log in error, most likely because I never downloaded that version in the past. So it looks as though I need to rollback to my previous (unknown) version. Thanks |
[2020-01-30 04:31:41] |
This is no longer the case. We are continuing to allow Top Step Trader but longer term later this year that service and others like it we intend to discontinue support for them. Just update to the latest version which is now 2040: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-30 04:31:52
