Date/Time: Tue, 04 Feb 2025 14:33:16 +0000
not getting connected
View Count: 548
[2020-01-29 21:05:08] |
Buffalo45 - Posts: 10 |
hello i have fully paid my renewal but this time im not getting connected its saying log on error
[2020-01-29 22:32:10] |
What Data or Trading service are you using or do you wish to use? See this page for the list: Table of Contents | (Supported Data and Trading Services) Or, select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Or, if you heard about Sierra Chart from a trading/broker service and want to use their service with Sierra Chart, tell us which one you were referred from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
