Date/Time: Sat, 18 May 2024 04:54:41 +0000
Looking for alternative way of creating spreadbars
View Count: 728
[2020-01-29 20:44:56] |
SierraFan - Posts: 84 |
Sierra is there another way of creating spreadbars other than using ratio study. Ex. Another platform/data provider you just type symbols EP/USA and the chart shows a clean chart of ES/ZB. Using ratio study creates a spreadbars chart just not as clean and granular as the other platform. I've attempted to just type the symbol in sierra and not have any success. I'm not complaining sierra, you guys are great. I'm just curious is there a way to create a spreadbar? Thanks for your time sierra, I've included 2 images. 1. the other platform http://prntscr.com/quqinl 2. Sierra ratio http://prntscr.com/quqi8v http://prntscr.com/quqinl http://prntscr.com/quqi8v |
[2020-01-30 00:12:21] |
Yes this is supported with this feature: Custom Calculated Symbols Make sure you are running a current Sierra Chart version though. This is absolutely essential for proper support for the historical data. Update with Help >> Download Current Version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-30 19:11:19] |
Sierra_Chart Engineering - Posts: 14423 |
We do not accept chart images from external services. Provide a chart image following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-30 19:16:21] |
Hi Sierra, I'm having an issue with creating ESH20/ZBH20 spreadbar (CustomCalculatedSymbols) when using SC Futures Order Routing. If I use Sierra all services data the ESH20/ZBH20 shows up fine. Is there something I need to change in the values window when using SC order routing?
[2020-01-30 19:25:25] |
What is the exact formula symbol you are using? What is the exact problem? Also refer to post #4 above.
[2020-01-30 21:14:44] |
Thanks for the quick response Sierra. I was putting the wrong formula in SC Order Routing. {ESH20}/{ZBH20} When I was suppose to use this.{ESH20_FUT_CME)/{ZBH20_FUT_CBOT} Thank You for bringing this to my attention.
