Date/Time: Sat, 18 May 2024 08:23:06 +0000
Sierra Chart Routing/ TT MIT orer issues AMP
View Count: 710
[2020-01-30 06:40:36] |
The CME does not natively support market if touched orders and we tried using the TT implementation of market if touch orders, and the behavior was incompatible with Sierra Chart because they just trigger a whole completely separate order which is a problem. So we have to develop these on the server side but there are a lot of details to this. We will try to have it done this year. Regarding: On a side note my second instance is also not getting data with Denali either probably a setting
Follow the instructions here to clear the Message Log:Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-30 15:28:23] |
User450179 - Posts: 105 |
i went back and re read my post about order types and you listed them and it did not include MIT orders. it did say enable attached orders under global settings though for server side oco and bracket orders concerning this. I took that to mean ordrs like LIT and MIT. is there a limit if touched. thanks] |
[2020-01-30 19:04:58] |
Sierra_Chart Engineering - Posts: 14423 |
You will need to use this order type instead: Order Types: Market if Touched - Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-30 20:56:42] |
User220914 - Posts: 239 |
In response to using the CLIENT side MIT order i would say that is some latent data for sure sending those MIT orders and pretty much negates the entire reason for paying for co location
[2020-01-31 00:52:34] |
Yes we understand. But this is all that is available at this time for that order type when using our TT order routing. We tried to implement what TT offered but it was not usable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-31 00:52:44
[2020-01-31 02:51:18] |
ok thank you it is still a great service hopefully maybe just get an MIT or LIT and let all the other fancier stuff wait until later.
[2020-01-31 04:50:26] |
I have no idea how much engineering and programming must go on with sierra chart. thanks fo rputting together a superior product. it's fast thank you. client side mit is actually working pretty quickly thanks |
