Date/Time: Sat, 18 May 2024 05:11:35 +0000
TPO Profile Study OHLC Subgraphs
View Count: 684
[2020-01-29 17:45:45] |
User806682 - Posts: 10 |
Hi, I see that the TPO Profile Study has subgraphs for OHLC values, but rather than having each index match the OHLC for each bar in a profile, it has the same OHLC values for many indices until it reaches the previous profile, and then it again duplicates all the OHLC values over many indices. Is it possible to provide the OHLC for each period in a profile at each index as you could expect on a regular bar chart? Thanks. |
[2020-01-31 21:07:57] |
Sierra_Chart Engineering - Posts: 14423 |
No. Refer to: Time Price Opportunity (TPO) Profile Charts: Chart Column Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
