Date/Time: Tue, 04 Feb 2025 14:43:14 +0000
anyway to show last n readings of an indicator on price graph
View Count: 632
[2020-01-29 16:12:43]
User774220 - Posts: 8
hello, i have alot of lines from various indicators which seems distracting as we all know..
i just want to show the last n bars worth of the indicator. I calculate based on previous bars, but only show last n bars, or from start of day, etc
OR maybe use the right edge where the most current levels are to push out toward the last price bar, trying to find ways to have the indicators lines, but clean it up a bit
hope i made sense. thanks
[2020-01-29 19:07:52]
Sierra_Chart Engineering - Posts: 18240
Also, look at the options for the Draw Style for the various indicator's Subgraphs. You may find a better way to display some of the data in various ways. In particular, note the option for Line at Last Bar to Edge:
Chart Studies: Subgraphs Tab >> Draw Style
[2020-01-30 03:48:18]
thanks, i have tried a bunch not nothing really works
the ideal would be to have an option in subgraph tab that has a drop down for "display amount" and the user can pick last n bars, day session, or pick a length. I did see some indicators that have an option in Input Tab for 'how many days to calculate' which is helpful, but not all have that...
thanks for response. if it makes sense to add in future developments that would be helpful, being able to control whats displayed without limiting calculations, etc
thanks
