Date/Time: Fri, 25 Apr 2025 16:08:26 +0000
Tradovate + Sierra Charts setup requirements?
View Count: 2467
[2020-01-29 02:30:49] |
asetnes83 - Posts: 21 |
Sorry I am not too familiar with Tradovate and how it works with SC. I'm certain I need service package 5, but not sure on what data and how to set this up. Server-side OCO bracket orders are important. Could someone help me with setting this up to use with Tradovate?
[2020-01-29 09:14:55] |
Sierra_Chart Engineering - Posts: 19343 |
If server-side bracket orders are important the only available services that we support for these is this one: Sierra Chart / Trading Technologies Futures Order Routing Service and Interactive Brokers: Interactive Brokers Trading Service Tradeovate uses CQG and the bracket orders on that service are incompatible with Sierra Chart. So you can not use Tradeovate with Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-29 09:15:29
[2020-01-29 13:41:53] |
Thank you, what data would I need if I were to just use it for real-time/historical data charting?
[2020-01-29 19:25:04] |
In this case, you can use the CQG market data feed and that broker will set you up with that: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
