Date/Time: Sat, 18 May 2024 09:53:42 +0000
Chart Time Label
View Count: 561
[2020-01-28 22:51:04] |
User824330 - Posts: 1 |
How do I drop seconds from the chart time axis? I want just HH:MM in larger font.
[2020-01-29 16:37:52] |
Refer to this setting to remove the seconds from the Time Scale: Chart Settings: Include Seconds on Intraday Chart Timescale (Chart >> Chart Settings >> Scale menu) The font for the time scale is controlled with the Chart Text Font. Refer to the Chart Text section of the following: Graphics Settings: Fonts and Text Appearance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
