Date/Time: Sat, 18 May 2024 13:22:31 +0000
sieera platform on lap top giving to friend can he use the existing platform
View Count: 452
[2020-01-28 22:07:58] |
User593615 - Posts: 5 |
giving my lap top to a friend that has sierra platform can he use the existing platform. or does he have to uninstall and sign up for a new account.
[2020-01-29 10:20:03] |
It is fine if they use it. As long as it is fine with you. But technically they should have a new account but there is no need to reinstall. They just change the account name on the Login window.
