Date/Time: Mon, 25 Nov 2024 02:29:20 +0000
dashed Vertical Lines hide Candle Wicks
View Count: 1827
[2014-01-04 04:39:18]
Rainer - Posts: 109
dashed & dot.dashed (& solid) vertical Lines hide Candle Wicks; see attached pic. (except dot vertical lines, but the dots are so close together and appear to be a solid line)
Can you please program SC for vertical Lines to appear behind Candle Wicks when placing these on charts?
Or at least, for the Dashed vertical Lines to be 'transparent', so that the Candle Wicks at least could be seen between the breaks of the dashes.
Date Time Of Last Edit: 2014-01-04 04:40:44
imageVertical Lines.JPG / V - Attached On 2014-01-04 04:40:35 UTC - Size: 52.76 KB - 503 views
[2014-01-04 13:57:15]
jsoviero - Posts: 84
+1 for suggestion described above
[2014-01-04 16:39:58]
tobi - Posts: 351
When you check "Draw Non-Highlight Chart Drawings Underneath Main Graph Studies"
in Chart >> Chart Settings >> Advanced Settings, vertical lines/drawings will appear behind the candles/wicks.
[2014-01-04 17:48:52]
There is a 0% chance we would ever implement transparency for a vertical line. That is very inefficient and complicated.
Anyway, are these vertical lines from a drawing Tool or from a Study? It is just a matter of setting them to display under the price bars.
[2014-01-04 21:21:46]
Rainer - Posts: 109
... from Drawing Tool, and thanks to Tobi_FX
To SC Engineers: please re-word this function to "Draw (Non-Highlight) Chart Drawings underneath Main Graphs & Studies"
Date Time Of Last Edit: 2014-01-05 00:25:26
