Date/Time: Sat, 18 May 2024 13:22:36 +0000
Rithmic support
View Count: 506
[2020-01-28 18:39:27] |
Vasyl Boshkov - Posts: 10 |
Hello This is from last release 2039: Support for Top Step Trader through Rithmic has been removed. You will need to use an older version of Sierra Chart if you want to use Top Step Trader. There is also available the Simulated Futures Trading service which can be used. It is relevant for Tepstep only? Or also for all of prop trading company's like Oneup, Earn2trade,LeeLoo ? Thank you in advance. Sincerely! Vasily |
[2020-01-28 19:47:26] |
Sierra_Chart Engineering - Posts: 14423 |
We have restored Top Step Trader for now but we are terminating support for all of them later in the year. And we will have an alternative before then. We already have this service: Simulated Futures Trading Service And none of those are proprietary trading companies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 20:08:29
