Date/Time: Sat, 18 May 2024 08:44:17 +0000
Diagonal lines drawn with line tool
View Count: 486
[2020-01-28 17:14:28] |
User459170 - Posts: 262 |
Diagonal lines drawn with line tool in higher timeframe chart, when shown in lower time (using Copy drawings from chart #) touch different price points along the way (not the same as higher timeframe) in the lower timeframe chart. Is there any way to fix it? Thanks. Date Time Of Last Edit: 2020-01-28 17:15:17
[2020-01-28 19:14:34] |
Sierra_Chart Engineering - Posts: 14423 |
Refer to the information here: Lines/Rays or Other Chart Drawings Move After Drawing Them: Chart Drawings Are Misaligned After Changing the Period / Timeframe Per Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-28 19:46:40] |
Thanks a ton, it was because of the anchor point ending inside the Right side fill space.
