Date/Time: Sat, 18 May 2024 12:47:04 +0000
Auto Chart Refresh to update 3rd party indicator data
View Count: 841
[2020-01-28 15:56:37] |
Trader8188 - Posts: 20 |
I use TAS Market profile on my sierra chart and Esignal. On Esignal I don't seem to have an issue with Tas Market Profile Boxes as they update automatically. At times in SC, some random lines appear. I have to click on the chart, press F5 and click OK to refresh it manually. Is there anyway that SC chart can refresh automatically, like every 30 seconds? Lines show up: https://imgur.com/7OhZAHf After pressing up F5 and click OK. https://imgur.com/JTiGFn1 |
[2020-01-28 19:29:55] |
Sierra_Chart Engineering - Posts: 14423 |
The first thing to try and do is get the developer to correct the problem. Another option is to use the following study to force a refresh automatically at certain time periods: Chart Recalculation - Periodic Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 19:30:25
