Date/Time: Tue, 23 Apr 2024 20:41:42 +0000
Delete in quote board
View Count: 474
[2020-01-28 15:34:22] |
User472677 - Posts: 316 |
In quote board, I have always been a le to delete a symbol by highlighting it and pressing the delete key. It no longer works. Is there a setting for this? How to fix this?
[2020-01-28 20:38:46] |
Sierra_Chart Engineering - Posts: 14062 |
We are not able to reproduce this. When a line in the Quote Board is selected that has a symbol entered, then selecting the Delete key will remove that symbol from the quote board. The only thing we can think of is that perhaps your Delete key is setup to perform a different function: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-28 22:18:54] |
I have cleared the shortcuts. Delete key still does not work.
[2020-01-28 23:06:05] |
This must be some kind of system specific issue.
