Date/Time: Tue, 04 Feb 2025 14:40:37 +0000
[Programming Help] - Using s_UseTool and sc.p_GDIFunction together to manilulate tool object
View Count: 594
[2020-01-28 15:27:49] |
User305536 - Posts: 60 |
Hello Support. I am wanting to use ACSIL to create an ellipse, and then customize the fill to color the top half and lower half with different colors. So, I see that for ACSIL you have the s_UseTool ability to add the tool objects with code, and that using GDI is also a possibility. So is it possible to use the GDI code to manipulate the Tool object? How would I get the handle? Thank you. |
[2020-01-29 23:35:58] |
After some research, I think what I am needing is the "HANDLE TO THE DeviceContext" for the Tool Object created in ACSIL. Where is that stored in Sierra Charts?
