Date/Time: Sat, 18 May 2024 12:27:07 +0000
add custom trade type to chart trade menu
View Count: 903
[2020-01-28 15:23:24] |
User658985 - Posts: 30 |
I created a custom trade type in the trade window. In the trade window, if i set it to limit, and enter the limit price, it will create a limit order of my custom trade type. Perfect. What i would like to do is be able to add my custom trade type through the chart, so i wouldn't have to manually enter the limit price (and possibly make a mistake). I know how to customize the trade menu items, bu tididn't see a way to add custom types. is this possible? even through ascil? thanks
[2020-01-28 19:08:11] |
Sierra_Chart Engineering - Posts: 14423 |
How did you add a custom trade type to the Trade Window? This is not supported.
[2020-01-29 00:23:35] |
I must not be explaining it correctly. Im referring to the functionality under the "targets" tab. I would like that same behavior applied through the menu, where the cursor of the mouse would automatically set the limit price for the custom rules created under targets
[2020-01-29 01:03:53] |
ok i think the right term is attached orders.
[2020-01-29 01:36:30] |
Yes this is fully supported. You just want to enter an order from a chart to set the price and also have Attached Orders attached. This is fully documented here: Chart Trading and the Chart DOM: Entering Orders From the Chart You can also use the Chart DOM: Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
