Date/Time: Sat, 18 May 2024 10:07:52 +0000
Using Trade and Current quote symbol to trade emicro
View Count: 675
[2020-01-28 14:43:03] |
User191165 - Posts: 28 |
Hello I've been successfully Using Trade and Current quote symbol & 'Use as Trade only symbol' to trade e-micros for the full benefit of reading Emini order flow. Only for the 6AH20 Dom, which has been working fine to date, I am now having order rejected and the following message saying 'Order price is outside the limits - which it is not. I have a video that highlights the process and issue, but don't want to post public as it has my account details. I'm also having numerous issues with the software ever since I moved over to Denali Thanks |
[2020-01-28 18:01:43] |
Sierra_Chart Engineering - Posts: 14423 |
We need to add a new setting to set the Price Multiplier for the Trade and Current Quote Symbol. That will correct the order price issue causing the error. We will work on that. For now use a separate chart for the symbol you want to trade. Tell us one issue you are having and just one issue only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 18:03:40
