Date/Time: Sat, 18 May 2024 11:02:10 +0000
My vbp is stuck at 5 tick intervals
View Count: 468
[2020-01-28 14:27:18] |
User232042 - Posts: 35 |
Hello, for some reason my VBP study only has the volume for a cumulative 5 ticks. Every time I try and change it back to 1 tick intervals it resets it to 5 ticks. Ill post some pictures below, thanks.
Date Time Of Last Edit: 2020-01-28 19:22:58
Screen Shot 2020-01-28 at 6.24.30 AM.png / V - Attached On 2020-01-28 14:27:00 UTC - Size: 169.07 KB - 208 views Screen Shot 2020-01-28 at 6.25.11 AM.png / V - Attached On 2020-01-28 14:27:08 UTC - Size: 306.23 KB - 209 views |
[2020-01-28 19:23:15] |
Sierra_Chart Engineering - Posts: 14423 |
Refer to the last paragraph in the following section: Volume By Price Study: Ticks Per Volume Bar (Ticks Per Volume Bar) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 19:24:37
