Date/Time: Sat, 18 May 2024 12:46:59 +0000
High Power usage
View Count: 982
[2020-01-28 12:07:44] |
User164231 - Posts: 278 |
Hello people.... Granted I have many charts opened (quite a few intra days in smallest of time frame), but even if I set to 20 days I still get the 'Very High' Power usage problem. What else can I do? |
SC Power Hungry.jpg / V - Attached On 2020-01-28 12:04:46 UTC - Size: 35.11 KB - 269 views Attachment Deleted. |
[2020-01-28 13:09:43] |
nosast - Posts: 290 |
This looks like one core of your machine is under full load. I have a similar issue when running a market depth chart in full screen with an update interval less than 250 ms. You can look in the resource manager (under performance in task manager) to see the usage of every single core. Date Time Of Last Edit: 2020-01-28 13:09:57
[2020-01-28 19:05:01] |
Sierra_Chart Engineering - Posts: 14423 |
Refer to Help Topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-29 02:56:21] |
Hi, I attach the CPU usage but I have no idea how to interpret it.
Date Time Of Last Edit: 2020-01-29 11:30:34
SC Power Hungry.jpg / V - Attached On 2020-01-29 02:55:02 UTC - Size: 27.13 KB - 276 views |
