Date/Time: Sat, 18 May 2024 05:11:45 +0000
acting as a DTC server, can incoming DTC messages be logged to disk?
View Count: 555
[2020-01-28 05:16:25] |
uM8137 - Posts: 180 |
Can SierraChart --when acting as a DTC server -- log to disk the DTC requests it sees from DTC clients? How could I do that? Thank you! Date Time Of Last Edit: 2020-01-28 05:16:36
[2020-01-28 06:12:37] |
Yes we can look into that but only if they are in JSON since that format is easy to log.
[2020-01-28 09:39:48] |
> only if they are in JSON since that format is easy to log. That defeats the point of logging, which is to be able to see all activity(!) And after all, dumping all raw message blobs amounts to the same thing, just not asking if they are json first--so even less work! I already have a binary protocol buffer DTC reader, so I can take it from there. Or, even easier, just an option to turn off TLS between Master and Subinstance would suffice (again, less work to do!); then Wireshark or any packet sniffer can do the logging that TLS prevents (without SSLKEYLOGFILE env variable support as in Chrome or Firefox) at the moment. |
[2020-01-29 18:21:39] |
Sierra_Chart Engineering - Posts: 14423 |
You can easily do your own logging when you send the messages.
[2020-01-29 19:23:18] |
I want to see the DTC messages that SierraChart is sending in certain cases, so I can emulate them from my DTC client.
[2020-01-31 04:25:16] |
I think I managed to figure it out without peeking. So not a priority now.
