Date/Time: Wed, 05 Feb 2025 09:55:49 +0000
Cannot change value format for TPO Chart
View Count: 727
[2020-01-28 03:41:28] |
User465507 - Posts: 74 |
I setup a TPO chart for XBTUSD-BMEX and the 'value format' is set to 0.1. Every time I try and change it to anything else it just switches itself back to 0.1. What would cause this?
[2020-01-28 09:29:43] |
Instead change the Price Display Format through Chart >> Chart Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 09:29:54
[2020-01-28 21:26:52] |
I can do that but was hoping to change the number format so I can see the volume numbers formatted differently. Does it just not work for the TPO study? |
[2020-02-14 03:34:05] |
^ bump. Not possible to get daily volumes to be displayed with the "large integer with suffix" value? Seems like even changing price display format as you've stated, won't help with this. Thanks |
[2020-03-08 01:52:33] |
This doesn't change anything for the TPO. |
[2020-03-10 17:57:44] |
When using the TPO Profile Chart study, then definitively changing the Price Display Format in the Chart Settings will definitively change the price format, not volumes, for the TPO chart. This has been verified.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-10 17:58:52
