Date/Time: Sat, 18 May 2024 10:41:59 +0000
log or errors
View Count: 463
[2020-01-28 03:13:02] |
User95303 - Posts: 1 |
Hi, I think think I sent my log with errors but not sure. Is someone able to help. I'm trying to install the options with current version to add the bridge part so I can run Rithmic. Thanks |
[2020-01-28 17:53:38] |
Sierra_Chart Engineering - Posts: 14423 |
You need to enable the option on the installer "Install Optional Components". Update again: Software Download: Fast Update We have discontinued technical support for Rithmic. If you are trading CME Group markets you need to move to this service: Sierra Chart / Trading Technologies Futures Order Routing Service If you are trading markets other than or in addition to CME markets, use this service: CQG Trading Platform Service If you are doing simulated trading, then use: Simulated Futures Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
