Date/Time: Sat, 18 May 2024 08:44:21 +0000
is this the correct feed?
View Count: 572
[2020-01-27 22:18:05] |
Robert Wojczak - Posts: 143 |
File attached.
is this the corrrect feeed.PNG / V - Attached On 2020-01-27 22:16:46 UTC - Size: 32.23 KB - 191 views is this the corrrect feeed.PNG / V - Attached On 2020-01-27 22:17:22 UTC - Size: 32.23 KB - 188 views |
[2020-01-28 03:59:50] |
We just need to you to answer us one question. Do you still have a Gain Capital trading account? Please answer within this thread and do not start another support request. Just simply type the message below and then click Submit New Reply.
[2020-01-28 11:28:43] |
yes I do
[2020-01-28 18:17:43] |
Sierra_Chart Engineering - Posts: 14423 |
We apologize for the delay. Therefore you need to set Global Settings >> Data/Trade Service Settings >> Service to Gain Capital/OEC. Complete instructions: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services (Integration with Trading Services) You also need to make certain that the symbols match the current service. Select Edit >>Translate Symbols to Current Service to do this: Edit Menu: Edit >> Translate Symbols To Current Service Do not start a new thread if you have another question related to this. Just simply post below. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 18:20:23
