Date/Time: Tue, 04 Feb 2025 14:04:12 +0000
Trade Windows Button
View Count: 564
[2020-01-27 18:32:20] |
pmd_Dedin - Posts: 5 |
Hello I would like to change the buttons on the Trade Windows. From BuyAsk, SellAsk, BuyBid and SellBid i would like to change to BuyStop, SellStop and BuyLimit, SellLimit. Please have a look at my attachment. Is that possible? Thanks for your support best regards René |
Bildschirmfoto 2020-01-26 um 12.38.10.png / V - Attached On 2020-01-27 18:31:12 UTC - Size: 761.27 KB - 235 views |
[2020-01-27 19:42:28] |
Sierra_Chart Engineering - Posts: 18240 |
You cannot do this but you can add buttons for these to the Control Bar: Control Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
