Date/Time: Sat, 18 May 2024 13:22:36 +0000
Commission
View Count: 606
[2020-01-27 16:10:25] |
User912405 - Posts: 14 |
I have the problem that the commissions are not included in the order fills. and this happens even though I -use Symbol Commission... --- had chosen. |
[2020-01-27 20:18:56] |
Sierra_Chart Engineering - Posts: 14423 |
Refer to the information here and ensure that you have all the options set correctly: Trade Activity Log: Use Commission Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
