Date/Time: Sat, 18 May 2024 09:05:26 +0000
gaps in data not showing on my charts
View Count: 783
[2020-01-27 15:48:07] |
User894550 - Posts: 20 |
I have an issue with gaps in price showing on my charts, the time on chart settings is set to the right time, and the "gap fill-none" setting is selected as well, but the gap in price is not showing on the chart.
[2020-01-27 20:10:15] |
Sierra_Chart Engineering - Posts: 14423 |
Please attach an image showing the issue you are having using these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
