Date/Time: Sat, 18 May 2024 09:53:45 +0000
Access Daily Price Change Percent via ACSIL
View Count: 553
[2020-01-27 15:27:19] |
User353585 - Posts: 66 |
Hello, is there any way that I can read the value of daily percentage change in the chart header(data region) via ASCIL? please let me know if it's any possible, thank you. Date Time Of Last Edit: 2020-01-27 15:27:52
[2020-01-27 20:11:20] |
Sierra_Chart Engineering - Posts: 14423 |
You have to calculate this. Refer to: Getting Quotes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
