Date/Time: Thu, 26 Nov 2026 15:31:29 +0000
How to create a change bar chart
View Count: 959
| [2020-01-27 10:17:16] |
| MIkebanks - Posts: 4 |
I wish to create a bar chart where bars open and close every (N) ticks against a visible and variable time axis. In other words, if it takes 4 hours for the first bar to form then 10 mins for the following bar the time axis needs to visually reflect this. Any help would be much appreciated. |
| [2020-01-27 20:31:54] |
| Sierra_Chart Engineering - Posts: 25493 |
Refer to the following setting: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar and look at the Number of Trades per Bar and Range per Bar options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
