Date/Time: Sat, 18 May 2024 09:05:24 +0000
DOM Question
View Count: 549
[2020-01-26 16:24:41] |
User316362 - Posts: 210 |
When I'm using the DOM and having an active order, If I have a tool selection active (not pointer tool) when trying to adjust the order, "sometimes" I end up drawing instead of selecting/adjusting the order if my selection on the order is not perfect. I have to be sure I have the pointer tool selected at all times when using the DOM to avoid this occasional problem. My question is, is there a way to disable drawings on the DOM so that I'm always in selection mode. Or maybe always default to the pointer when using the DOM even when a tool is selected for another chart? TIA Date Time Of Last Edit: 2020-01-26 16:53:59
[2020-01-27 20:38:58] |
Sierra_Chart Engineering - Posts: 14423 |
We will see what we can do but we recommend you use this setting to change change back to the Pointer automatically: Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
