Date/Time: Sat, 18 May 2024 04:37:11 +0000
Trade Activity Log - ver.: 2039
View Count: 473
[2020-01-26 07:14:36] |
nicktrader - Posts: 665 |
It is not possible to "Delete Trade Activity Entry/ Edit/ Insert" because it is not activate. Ver. 2038 still works. |
[2020-01-26 07:26:16] |
Nothing has changed with this functionality. We have verified there is no issue. You first need to select particular lines in the Trade Activity Log first for those commands to become active.
[2020-01-26 07:56:15] |
I know how it works to delete or edit. Pls take a look at the pic. |
TradeActLog.png / V - Attached On 2020-01-26 07:56:00 UTC - Size: 59.13 KB - 231 views |
[2020-01-26 08:19:06] |
In the 2039 installation you did not select the Trade Activity sub window through the menu at the top. The documentation does explain that.: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
