Date/Time: Sat, 18 May 2024 03:51:50 +0000
free Data for India National Stock Exchange (NSE) [End of Day only]
View Count: 1525
[2020-01-25 12:26:07] |
User95370 - Posts: 28 |
Hi, I use to had free data for India National Stock Exchange (NSE) [End of Day only] in previous versions of SC but I had to move to a new computer with new clean install and am unable to find symbols and data for the Index Nifty 50 and its stock components (like TCS, RIL, HDFC Bank,ONGC). Did you guys stop free EOD data for these?
[2020-01-27 18:36:40] |
Sierra_Chart Engineering - Posts: 14423 |
Historical Daily data is still supported and here is the symbol list: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=4#NSE You can also use this service: Global Data Feeds (India) Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
