Date/Time: Thu, 28 Mar 2024 15:39:17 +0000
Connection via Interactive broker
View Count: 609
[2020-01-24 18:06:29] |
Пользователь488020 - Posts: 81 |
Hello! I am contacting you again !! I need your help! I use Interactive Brokers in trading. I am subscribed to the US stock market data (NYSE). When I connect to the School, data volume is delayed for the first 15 minutes. On the chart, this data delay is displayed as a space. I upgraded to version 2038, read the recommendations, which were given in a similar situation by other traders. But the result is not working out for me. What do I need to do to make stock market data display normally, as on the charts of futures and Forex, where I have no complaints? I'm waiting for an answer. |
123SCh.jpg / V - Attached On 2020-01-24 18:04:42 UTC - Size: 280.33 KB - 240 views |
[2020-01-24 19:35:12] |
You are using Interactive Brokers data and we cannot help with that data. We recommend using this data feed instead which is fully integrated when using Interactive Brokers: Sierra Chart Exchange Data Feed You will need to activate this data feed and also activate the US Equities exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-27 17:30:50] |
Hello, in my case, for trading, I need the data of the Nyse exchange only, I will enter and trade through Interactive brokers. Question one. I only need one subscription of Nyse shares (U.S. Equities (NYSE, NASDAQ, AMEX, BATS), or else me need to connect a package for trading (For 20, ..., 100 Real-Time Symbols)? Question two. Where can I find out about Nyse stock data (U.S. Equities (NYSE, NASDAQ, AMEX, BATS), (what do it include)? As it seems to me, there is no detailed information about the quality of data and its components on the page following the link you gave me. Thanks. |
[2020-01-27 19:49:08] |
Sierra_Chart Engineering - Posts: 13609 |
You will need to pay for the real-time connection and that can be for either 20 symbols or 100 symbols and then you will also need to activate the US Equities exchange.
[2020-01-28 14:13:35] |
OK, but I didn't get the answer, what data will I get? This will be the depth of the market, volume, volatility, how will they be related to the market data of the Nyse exchange?
[2020-01-28 19:25:31] |
Price and volume data will be provided. Not market depth data. The market data from the exchange will be included.
