Date/Time: Fri, 29 Mar 2024 00:26:45 +0000
Duplicate Quote Board
View Count: 757
[2020-01-24 17:24:01] |
ycomp - Posts: 274 |
is there a way to duplicate a Quote Board to another workbook? if not, is there some way to copy / save / import the layout to another quote board? so that I don't have to reconfigure all the columns and column widths? Date Time Of Last Edit: 2020-01-24 17:25:04
[2020-01-26 00:08:23] |
Sierra_Chart Engineering - Posts: 13611 |
No, there is not a way to duplicate the layout of a Quote Board to another Quote Board. But, what is available is the ability to keep the Quote Board available regardless of what Chartbook you have open, and also to be able to link across Chartbooks. This gives you the ability to have a single Quote Board for multiple Chartbooks. Refer to the following: Getting Quotes: Always Visible or Always on Top Getting Quotes: Quote Board Linking Across Chartbooks You can also export the symbols in one quote board and import them into another. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
