Date/Time: Fri, 29 Mar 2024 11:04:09 +0000
I am using dxFeed as my data provider. How can I make it work with my Sierra Charts?
View Count: 1406
[2020-01-24 16:19:01] |
willypbm - Posts: 6 |
[2020-01-24 19:30:15] |
This is inherently not supported and cannot be due to restrictions by that data feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-24 19:30:21
