Date/Time: Tue, 23 Apr 2024 17:16:28 +0000
Wrong Tick Value Shown for MES
View Count: 679
[2020-01-24 07:29:27] |
sourdubber - Posts: 52 |
Isn't the Tick Value set automatically by SC? Currently it shows the value of $12.50 for MES, whereas it should be $1.25. Do I need to modify this value manually? FYI I am using the same spreadsheet formula (set to sheet1) for both ES and MES. Thanks. |
[2020-01-24 19:53:22] |
Sierra_Chart Engineering - Posts: 14057 |
If you are using a "Trade and Current Quote Symbol" you will need to manually adjust the "Currency Value Per Tick": Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
