Date/Time: Fri, 26 Apr 2024 03:31:26 +0000
Fxcm sierra charts order quantity
View Count: 794
[2020-01-24 04:42:33] |
mutales-way - Posts: 1 |
HI,I HAVE TROUBLE GETTING THE ORDER QUANTITY SETTINGS RIGHT FROM SIERRA CHARTS I OPENED 2 LIVE TEST POSITIONS WITH A $15 STOP LOSS WITH A NET LOSS OF -15.71AUD, HOWEVER THE ACTUAL LOSS REFLECTING IN FXCM TRADE STATION IS -229.81AUD.I HAVE ATTACHED TWO IMAGES SHOWING THIS ,YOU CAN SEE THE LOSS IN THE TRADE ACTIVITY LOG AS -15.71AUD(AS INTENDED) AND ALSO IN THE FXCM TRADE AS -229.81 AUD. IAM AWARE OF ORDER QUANTITY FROM FXCM AND I WAS USING THE CHART TRADING DOM WITH BRACKET ORDERS ALREADY SET. SO I JUST INPUT NUMBER OF TICKS FOR STOP LOSS AND THEN I ADJUST ORDER QUANTITY ACCORDING DOLLAR VALUE BEING GENERATED BESIDES THE STOP PARAMETERS DOING THIS RESULTS IN BIGGER ACTUAL POSITION BECAUSE THE ORDER QUANTITY SUGGESTED BY THE DOLLAR VALUE FROM STOP LOSS IS WAY OUT.HOW CAN I SOLVE THIS ERROR? PLEASE FIND BOTH IMAGES ATTACHED |
sierrav charts trade service log.PNG / V - Attached On 2020-01-24 04:41:16 UTC - Size: 29.77 KB - 223 views |
[2020-01-24 19:29:34] |
The question is what is the currency value per tick for USOil on FXCM. We have to check on that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-24 19:29:51
[2020-01-26 04:24:37] |
Sierra_Chart Engineering - Posts: 14092 |
We have corrected the currency value per tick for USOil and UKOil. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Reference: http://docs.fxcorporate.com/user-guide/ug-cfd-product-guide-ltd-en.pdf Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-26 04:25:01
