Date/Time: Wed, 24 Apr 2024 15:10:17 +0000
SC All Data & Future Spreads
View Count: 738
[2020-01-23 21:05:14] |
User645473 - Posts: 9 |
Hello, I'd like to build this Futures Spread: NGK20 - NGN20 I've connected SC to the Data/trade Service Setting "SC All Data" (image NG1) In attach the image of the symbol I've put into the Chart Settings (image NG) Thank you very much |
Private File Private File |
[2020-01-27 20:25:37] |
Sierra_Chart Engineering - Posts: 14071 |
We apologize for the delay. This had gotten overlooked. And we do appreciate you using the Support Board and we apologize that we overlooked it. If the cause is what we think it is it is now resolved. Update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
