Date/Time: Fri, 26 Apr 2024 04:33:28 +0000
Flatten positions at time issue
View Count: 814
[2020-01-23 19:46:25] |
SilentH - Posts: 16 |
For the life of me, I cannot figure out how to disable this feature. My positions are flattened at 11:29 am pst everyday and I have disabled this feature in the global PnL mgmt section. I thought maybe it was a spreadsheet for trading I was testing for a while with this feature enabled. I need help isolating where this is generating so I can disable it. Let me know if I need to attach my chartbooks. Thanks Date Time Of Last Edit: 2020-01-23 19:46:57
[2020-01-23 20:46:19] |
Sierra_Chart Engineering - Posts: 14092 |
This is on the A tab of the Trade Window: Basic Trading and the Trade Window: A >> Flatten And Cancel at Set Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-28 22:36:43] |
User884103 - Posts: 19 |
I am having the same issue - Trade window tab A 'flatten & cancel at set time' is disabled.
[2020-10-29 02:46:45] |
We need to know the origin of the order flattening the position. Instructions: Trade Activity Log Analysis: Determining the Origin of a New/Modified Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-01 06:17:54] |
I am having the same issue. I have disabled 'flatten & cancel' in trade window, and global PnL management. This occurs daily at 13:29, and the only info under 'OrderActionSource' in the trade activity log is the following: Unable to Flatten or Reverse because a Position does not exist. |
[2021-06-01 06:29:48] |
I found the issue - Several other charts in my chartbook (besides my trading time-frame) still had 'flatten & cancel at time' on in respective trade windows.
[2021-06-01 07:31:39] |
We will make sure the logging, even in this case, shows the source of the flatten operation.
