Date/Time: Fri, 26 Apr 2024 14:45:25 +0000
crosshair problem
View Count: 727
[2020-01-23 19:09:15] |
luc1280 - Posts: 2 |
Hello, When I move the crosshair on one chart (having two charts side by side) the other chart follows the move of the crosshair moving the chart to that date. This didn't happen before and I don't know how to stop it. Any ideas? thank you, Luciano |
[2020-01-23 20:31:44] |
Sierra_Chart Engineering - Posts: 14101 |
You need to disable this option on the menu: https://www.sierrachart.com/index.php?page=doc/Tools.html#SynchronizeCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
