Date/Time: Thu, 25 Apr 2024 12:54:10 +0000
Inaccurate Volume Profile
View Count: 594
[2020-01-23 17:59:15] |
User207252 - Posts: 14 |
I'm using a previous day volume profile and the profile highlights wrong VAH, VAL, and gives excess lows? For example, yesterday's low for ESH20 was 3315.25 while my previous day volume profile shows a low 3313.00? I have already used the input settings for a previous day profile provided by the link below https://www.sierrachart.com/index.php?l=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#1DayVolumeProfileForPriorDayAtEndOfChart |
[2020-01-23 20:23:42] |
Sierra_Chart Engineering - Posts: 14076 |
Usually when there is something like this it is related to having the wrong Session Times. Refer to the following for more information on Session Times: Chart Session Times: Session Times Also, refer to the following for troubleshooting this issue: Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
