Date/Time: Wed, 17 Apr 2024 21:24:02 +0000
Chart discrepancy from other charting platforms
View Count: 522
[2020-01-23 16:56:21] |
User276793 - Posts: 47 |
this is not the first time i have noticed this but it is very relevant this time. sierra charts looking different from other charting platforms even the charting platform for interactive brokers, and i use IB data for sierra? Not sure if this is something to do with my settings but i would like to fix this if possible. Pls see attached file thanks |
Sierra charts vs IB ES.docx - Attached On 2020-01-23 16:54:37 UTC - Size: 589.28 KB - 243 views Attachment Deleted. |
[2020-01-23 17:31:08] |
User907968 - Posts: 802 |
Your SC chart shows 1hr bars beginning at the bottom of the hour (##:30), whereas the others show 1hr bars beginning top of the hour (##:00). Did you try enabling 'New Bar at Session Start'? Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) |
[2020-01-23 21:20:01] |
Sierra_Chart Engineering - Posts: 13969 |
Check the bar starting times: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-25 05:23:22] |
I changed session start times and it made the chart look different but not like the other charts or even close. I'm not sure i want the candles to start at the session break as i am not sure that is how other people with other platforms would view the chart. Not really sure how to fix this. |
[2020-01-27 19:03:53] |
Another setting to check is: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
