Date/Time: Thu, 28 Mar 2024 14:24:37 +0000
Alert Scan Triggering On Historical Day
View Count: 449
[2020-01-23 12:18:22] |
User49270 - Posts: 48 |
Hi, when I run a scan for an alert it seems like I'm getting an alert for a stock before all the data is downloaded, the alert should have triggered at that time. Once all the data loads the current day should not have triggered the alert. Thanks
[2020-01-24 17:54:22] |
Sierra_Chart Engineering - Posts: 13607 |
You need to follow through the instructions here: Study/Chart Alerts And Scanning: Understanding Scanning Historical Daily Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
