Date/Time: Thu, 09 May 2024 17:33:43 +0000
User Defined Name in Alerts
View Count: 485
[2020-01-23 01:46:30] |
SirK - Posts: 16 |
I am trying to send an alert to an email and but i only want the user defined name nothing else. Is this possible?
[2020-01-24 09:58:53] |
Sierra_Chart Engineering - Posts: 14292 |
Refer to this option: General Settings Window: Use User Defined Name Only in Alert Message (Global Settings >> General Settings >> Alerts >> User Defined Name) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-27 21:20:53] |
SirK - Posts: 16 |
So if i follow that set up and its still not sending my user defined name what can be done?
[2020-01-28 17:49:34] |
There is definitely not a problem with this. We tested this and only the user defined name was sent. What is the option you enabled for this in Global Settings >> General Settings?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 17:50:15
