Date/Time: Fri, 26 Apr 2024 13:39:30 +0000
sharing chartbook
View Count: 563
[2020-01-23 00:15:48] |
JDP6 - Posts: 9 |
a user has sent me his chartbook to share; i am opening it up but it just shows up black. nothing is uploading. please advise. |
[2020-01-23 02:43:21] |
Sierra_Chart Engineering - Posts: 14099 |
You may need to translate the symbols. Use this command on the Edit menu: Edit Menu: Edit >> Translate Symbols To Current Service (TranslateSymbolsToCurrentService) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
