Date/Time: Fri, 19 Apr 2024 13:30:31 +0000
Speed -
View Count: 509
[2020-01-22 16:16:50] |
User325213 - Posts: 3 |
Hi all - Where can I check - for speed and data settings - Everything seems to bee running slow - It's not the hardware - Dell XPS 8920 32G Ram 300 MBPS Spectrum - DOM loads slow - Charts jump - Rithmic says I have a lot of lost data connections - I dont know what a lot means - That window never comes up - Frustrated - Not a software programer kinda guy |
[2020-01-22 22:19:36] |
Sierra_Chart Engineering - Posts: 14008 |
We definitively recommend not using Rithmic as Sierra Chart has discontinued support for Rithmic. We recommend using this service: Sierra Chart / Trading Technologies Futures Order Routing Service Your problems will be solved with the above service. Or you can use CQG: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-22 22:19:49
