Date/Time: Mon, 25 Nov 2024 01:47:29 +0000
2 Sierra instances on one PC
View Count: 1420
[2014-01-03 13:54:21] |
EuropeanTrader - Posts: 290 |
Hi, if I install 2 Sierra instances on one laptop with 2 different directories for files, will it run smoothly or can I expect any problems? I need to execute my trades through IB data but have to use another data for charting since IB historical in not reliable. Is there any other solution to that, which is the main problem really? Thanks |
[2014-01-03 14:01:22] |
ganz - Posts: 1048 |
EuropeanTrader http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php |
[2014-01-03 15:14:51] |
skoosht - Posts: 13 |
I ran two instances on a Dell Venue Pro 8" tablet and it runs smoothly. Sierra is very lightweight. I run 3 instances with 2 different brokers on a Core 2 Duo desktop with no slowdown that i can see. |
[2014-01-03 17:10:16] |
There is no problem running multiple instances of Sierra Chart on your computer. Here are the instructions: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html For a better quality data feed when using Interactive Brokers we recommend the Sierra Chart real-time futures data feed : http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
