Date/Time: Fri, 29 Mar 2024 13:37:27 +0000
data
View Count: 483
[2020-01-21 21:43:45] |
User901605 - Posts: 2 |
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2020-01-21 17:22:56.731 GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2020-01-21 17:22:56.773 GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2020-01-21 17:22:56.773 GAIN Capital FIX Trading: Connected to FIX server. | 2020-01-21 17:22:56.900 GAIN Capital FIX Trading | Sending the Logon message. LocalCompID= | 2020-01-21 17:22:57.091 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-21 17:22:57.478 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-21 17:22:57.479 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2020-01-21 17:22:57.479 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-01-21 17:22:57.479 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-01-21 17:22:57.479 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-21 17:22:57.479 GAIN Capital FIX Trading socket (1) | Closed. | 2020-01-21 17:22:57.479 GAIN Capital/OEC | Disconnected from the trading server. | 2020-01-21 17:22:57.480 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2020-01-21 17:22:57.490 GAIN Capital/OEC | Disconnected. | 2020-01-21 17:22:57.490 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-01-21 17:22:57.490 Date Time Of Last Edit: 2020-01-21 22:10:51
[2020-01-21 22:12:00] |
Sierra_Chart Engineering - Posts: 13625 |
These are the relevant messages: GAIN Capital FIX Trading | Sending the Logon message. LocalCompID=Royalwinner | 2020-01-21 17:22:57.091
Refer to:GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2020-01-21 17:22:57.478 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2020-01-21 17:22:57.479 https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
