Date/Time: Wed, 24 Apr 2024 12:05:40 +0000
Incorrect work of SC
View Count: 495
[2020-01-21 18:38:24] |
User556056 - Posts: 10 |
Hello SC does not display correctly information. I restarted the program and the computer several times. The problem remains. No way to work |
Private File Private File |
[2020-01-22 08:18:56] |
Problem still exists! Help to fix this problem! Why is not all data displayed? When you will fix the problem? |
[2020-01-22 18:32:40] |
John - SC Support - Posts: 31059 |
This is related to the Gain Capital data issue. We are working with you on this in this thread: Please help For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
