Date/Time: Fri, 26 Apr 2024 14:19:52 +0000
SCSS LAST PRICE verses SETTLEMENT
View Count: 463
[2020-01-21 06:02:32] |
User733502 - Posts: 44 |
Hi SC, I'm using the SCSS function to collect data create formulas to produce analytics. I have the study created in DAILY WEEKLY and MONTHLY chart using the LAST price command which is what i want. ES CME SP500 closes at 3:59:59 and I want the LAST price at that time. Instead I'm getting the SETTLEMENT price for the session. How do I get the LAST price for my SCSS sheet? Appreciate the support Thank you |
SC LAST.png / V - Attached On 2020-01-21 06:01:11 UTC - Size: 205.71 KB - 236 views |
[2020-01-21 10:33:54] |
You can only obtain that from an Intraday chart.
