Date/Time: Fri, 26 Apr 2024 16:51:15 +0000
Alert Manager window no longer shows the CONTROL buttons...
View Count: 476
[2020-01-21 05:51:06] |
User19546 - Posts: 7 |
I've just gone from v1924 to v2028. My Alert Manager window no longer shows the CONTROL buttons (Close, Clear Log, Go To Chart, Go To Chart and Close). What do I need to do to get the buttons back? Date Time Of Last Edit: 2020-01-21 05:53:51
Alert Manager window v2028.JPG / V - Attached On 2020-01-21 05:50:41 UTC - Size: 20.64 KB - 204 views Alert Manager window v1924.JPG / V - Attached On 2020-01-21 05:53:32 UTC - Size: 30.25 KB - 236 views |
[2020-01-21 10:34:24] |
They have been replaced by the menu commands at the top.
